How to fix the issue Network dataset stop working when editing through ArcGIS Pro?
2827
01-25-2023 01:01 AM
UndrakhBatkhishig
I had already published the Road Network analyst service which I have to update now. When I complete editing the road centerlines through ArcGIS Pro, it will stop working accidentally. Has anyone faced this type of issue? How can I edit the network dataset using ArcGIS Pro (2.9) ?
MelindaMorang
Hello.  From your screenshots, it appears that Pro has crashed.  The best thing for you to do is to add your e-mail and a description of your workflow in the crash dialog (the one shown in EditIssue3.jpg) and click "Send Report".  These reports are sent to a sorting system here at Esri, and it will be sent to the best team to address the problem.  If you include your e-mail, the team may be able to reach out to you to help you find a workaround.
You can also call Esri Support for more immediate help.
MelindaMorang
You could also try installing ArcGIS Pro 3.0 (the latest release available as of today) and seeing if the crash has been fixed.
