How to Export / Import Geometric Network in ArcGIS10
6093
05-31-2012 06:43 AM
by Anonymous User
Not applicable
Original User: basavaraju_dba
We need help to export/import the Geometric Network from ArcCatalog10
We could be able to export or import the Geometric Network in ArcCatalog9.3 with geodatabase designer 2.
Is there any kind of utility available which is compatabile for ArcGIS10 to export Geometric Network(Like geodatabase designer 2).
Oracle Database Version: 11.2.0.1
ArcSDE Version: ArcSDE 10
ArcGIS Version: ArcGIS10 with Service Pack4.
Your help in this context is highly appreciated.  Thank You.
-BasavaRaju
philippenn
Use the Geometric Network Configuration Manager if you are at 10.2
Geometric Network Configuration Manager | Applications Prototype Lab
by Anonymous User
Not applicable
Original User: ingmars
Hi there,
I have the exact same question, and I really wonder how this is meant to work at all. There must be a way to export the network topology of geometric networks, but I simply cannot figure out a way how to do this. Any help would be greatly appreciated.
Kind regards,
Ingmar
philippenn
