How to apply different impendance by Break field for facilities in service area network analysis?
1099
04-04-2018 01:40 AM
FangdaLu1
When I try to use Break_Miles field to set impedance for every signle facilities, it seems no effect but only use the default breaks. How can I apply my Break_Miles values to network solving?
According to http://desktop.arcgis.com/en/arcmap/latest/extensions/network-analyst/service-area.htm#GUID-21ADEC62..., I set this field as text field, the value is looks like "1 3 5" or "3 5 10", numbers divided by space means breaks value for each facilities.
Any mistake I made?
Tags (1)
MelindaMorang
Make sure you're using "Miles" as your impedance attribute.  Or, if you want to use a different impedance attribute, make sure you populate the associated Breaks_[impedance] field.  They must match.
FangdaLu1
Yeah I make sure they do matched.
