Failed to Generate Directions, Error
10652
13
11-10-2010 09:25 PM
FrankPerks
So for the last week or so, i have been working on a project, and have been able to generate directions in the past. However now every time i try to generate directions i receive the error
"Failed to Generate directions. Network dataset does not support driving directions."
I did this several times, didn't work:
http://resources.arcgis.com/content/kbase?fa=articleShow&d=29034
The only thing that seems to work i just nuking my entire network dataset and recreating everything (which i absolutely do not want to do).
I have restarted ArcGIS, repaired ArcGIS, everything seems fine. I am guessing somehow my network dataset has become corrupt?
I am using ArcGIS 10
YousefEsmaeili
I have the same problem. did anyone find a solution ?
Regards
PeterLöfås
Hi all,
I had the same problem with failed to generate directions.
I managed to solve it by changing my regional settings to EN-US on my computer.  There is probably some kind of error in how cultures are handled when generating the directions.
ReemMahrous
for a network dataset to allow directions, all participating features classes should have a text field
KristoforCarle
I had the same issue with the ND reporting "Directions: Yes" in ArcGIS 10, but still displaying an error when attempting to open the directions.
Here are the steps that worked for me:
  • Configure the directions settings in the ND
  • Rebuild the ND
  • Close and reopen ArcMap
  • Resolve the route
Closing/reopening ArcMap is the main thing I was missing. I guess it doesn't pick up on the change in the ND until it is reloaded.
