Patrick,
Thank you for responding. I am not using barriers. When I build the network, I am only using using the right turn option, census road data - vertex selection. no elevation, and no directions. At first I thought it had to do with projection, but I checked that over and over. What type of values am I to look for that are not in the range of positions. I have no clude as to what "range of positions" represents.
I have had to break the data down by areas to run the new routes, and the one's I could not get to work, I just let be. I was planning on breaking those addresses down further hoping to see which address is giving the problem.
Any suggestions?
Margaret
