error : routed due to violated constraints.
1908
01-29-2021 01:55 AM
amirky434
We've been working with the network analyst to perform a VRP (vehicle routing problem).  We have been modifying and adding to the VRP. But the network gives an error and the routing is not done. please help
Network image in arcmap  was attached
Tags (1)
DanPatterson
MVP Esteemed Contributor
anything in the output that would provide a reason?
Output from Solve Vehicle Routing Problem—ArcGIS Pro | Documentation
... sort of retired...
HeatherMoe
As mentioned above the Orders and Routes have ViolatedConstraints fields that should provide some more detail about why it is not solving. The Status field on the orders might also give a clue if they are not locating correctly.
