Error opening network dataset in ArcMap
1297
04-26-2021 07:08 PM
meg1320
Hi there,
I created a network dataset in ArcCatalog and am now trying to get it into ArcMap. Issue is that I am getting the error "Open Failed. Error opening network dataset. Invalid network dataset name" when adding the .nd file. The name is the default name created by ArcCatalog, so I don't understand how it is invalid.
Any help would be greatly appreciated.
meg1320
Nevermind, found a work around.
JayantaPoddar
Great! Could you share the workaround? This will help other users with similar problem.
Think Location
