Distance between Multiple Addresses
1773
06-08-2012 04:17 PM
TimothyFrichtel
I need help mapping several addresses and then find the distance between each location and all the other addresses, essentially creating a matrix.  I don't have access to the extensions such as the network analyst so any help on other ways I can get this information would be really helpful.  Thanks so much.
AlexeyTereshenkov
The Point Distance tool should work for you:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00080000001r000000 (ArcInfo only)
There is a good blog post on calculating distances between points too: http://blogs.esri.com/esri/arcgis/2011/07/21/calculating_geodesic/
TimothyFrichtel
Thank you very much, really appreciate it.
