Delay in routes
1984
6
09-01-2024 09:00 PM
DevakalaiselvanS
I wish to establish a delay for a specific path. In network analysis, is that possible? I require guidance.
JaySandhu
The wait at a traffic signal depends on when the car arrives there and also which direction it will go, i.e., straight, left, right or U-turn. So how are you modeling the delay? One way is to simply delay the overall speed/travel time on all the edges or add a user junction at the traffic signal junction and add a junction delay in the network dataset.  Or use the turn category evaluator in the network dataset to set up the delays. More info here:
Turn category evaluator—ArcGIS Pro | Documentation
Jay Sandhu
JaySandhu
If your goal is to delay a path, and you have that path as some line feature, then you can load it into a route analysis layer as a Line Barrier with scaled cost. Set the cost with the amount of delay. See more here:
Barriers—ArcGIS Pro | Documentation
Jay Sandhu
DevakalaiselvanS
i don't want to change the route direction
JaySandhu
I am not sure what it means to not change route direction. Can you explain what you need to accomplish?
Jay Sandhu
DevakalaiselvanS
How to add the waiting time for a traffic signal to a route.Normally, the entire time is displayed. I'd like to increase the overall wait time.
JaySandhu
Jay Sandhu
DevakalaiselvanS
thank you
