Data structure of network file
2875
08-05-2012 01:51 PM
XuebinWei
I want to write some python program to read the attribute of a established network. I found the ArcGIS can build a network very quickly and generate a folder of ??????Newtork_ND.nd with some files of ???.nds.
How does those files store the topological relation of network, like the connected edges and junctions?
Thanks.
JaySandhu
The contents of the network dataset folder are in a binary proprietary format. However you can access the attribute information of a network dataset from python using the describe function. More here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v00000055000000
With 10.1 there are additional python functions for network analyst. You can read more about that here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//01mr00000012000000
Jay Sandhu
XuebinWei
Hi Jay,
Thank you for your reply.
Is there a way that arcpy can read those attributes of a single edge of a network, just like the  [Network Identify Tool] can easily find the connected edges and junctions of any selected edge?
[ATTACH=CONFIG]16707[/ATTACH]
Xuebin
