create route fails with error 000443
1303
05-02-2011 06:58 AM
QuinnMcCarthy
Every time I run create route I get this error. Here is the solution in the help: Review the log file to examine the errors encountered during route creation to see how to proceed. One of the more common errors you might encounter is "The measure value is outside of the output M domain." This error occurs when an m-value being assigned to a route feature falls outside the allowable m-range as defined by the m-domain. To resolve this, ensure the m-domain defined for the output route feature class is appropriate for your data. Where do I adjust these setting to appropriate values when I run create route? I am using the 2 field option.
Thanks in advance.
Quinn
