Create 1 polygon around 8000 point
5763
08-14-2015 12:14 AM
IgnatiusRumambi
Dear all,
I have one layer points with about 8000 points (see pdf example attachment), I want to create 1 polygon to the outer portions of these points,
these are the points where the accessibility of aid provision (fire) in certain time, for example 5 minutes.
It would be better if I do this with Network Analyst, but at the moment still too difficult for me, the accessibility from one point within five minutes (time diameter). But that's my next step.
is there any possibility to solve this ?, please help,
John Rumambi
DanPatterson_Retired
That is a concave hull
https://community.esri.com/blogs/richard_fairhurst/2015/06/11/bruce-harolds-concave-hull-estimator-t...
and it is more difficult to create than a convex hull
http://desktop.arcgis.com/en/desktop/latest/tools/data-management-toolbox/minimum-bounding-geometry....
decide how important the differences are given your point pattern
JayantaPoddar
Hi John,
You could also try this
Aggregate Points (Cartography)
Define a very high value for the Aggregation Distance, so that all the points are considered in a single cluster.
Think Location
IgnatiusRumambi
Hi everyone,Thanks for the quick response, this is what I was looking for ....My best regards,John Rumambi
#yiv8116561539 * #yiv8116561539 a #yiv8116561539 body {font-family:Helvetica, Arial, sans-serif;}#yiv8116561539 h1, #yiv8116561539 h2, #yiv8116561539 h3, #yiv8116561539 h4, #yiv8116561539 h5, #yiv8116561539 h6, #yiv8116561539 p, #yiv8116561539 hr {}#yiv8116561539 .yiv8116561539button td {}
GeoNet
Rebecca Strauch marked Dan Patterson's reply on Create 1 polygon around 8000 point as helpful. View the full replyMarked as helpful:this is a better linkhttp://desktop.arcgis.com/en/desktop/latest/tools/cartography-toolbox/aggregate-points.htmbut it requires an advanced license
Following Create 1 polygon around 8000 point in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
