I've run in to the common "Out of Memory" problem when running a closest facility Solve. However, I'm only running it on 256 facilities (schools) and 1144 incidents (villages)*. I've tried the following:
... But keep getting the same error. I am wondering if it has to do with my data being corrupt, or if this can be solved by getting the 64bit extension to ArcMap.
*Solve has run successfully when performed over two other facilities datasets, one that is 52 points and one that is 158. I only have issues when running on the 256-facility dataset.
Does any one have ideas about how I can get this to work? Thank you very much in advance!
Hi Jo,
Would you not want to 'chunk' your incidents rather than schools?
