Can VRP's route solution be optimised?
1533
02-28-2022 09:55 PM
Barbara_Araujo
I couldn't find a better way to word my title but I will explain the situation.
I need to model collection routes for a single truck. Working time is from 08:00 - 12:00, then 13:00 - 15:00. Break is from 12:00 - 13:00. This is the case for three cities (three independent VRP analyses). There is always only one depot.
Initially I had problems getting VRP to function, so up until recently I have been generating routes manually with Route Analyst. I basically divided the collection points in rough groups that made sense geographically and that I estimated would fit in the 08 - 12 or 13 - 15 schedule, with the depot as starting and ending point. Of course, it took a lot of time and credits because I rarely got it right on the first try.
Last week, I finally figured out my problem with VRP and re-ran the routes I had already modelled. The results are very different, but not in the sense I was expecting.
For VRP, I created a "Routes" sheet with three identical pairs of the 08 - 12 and 13 - 15 working times, totalling 6 routes. They weren't always fully used but I wanted to make sure the programme didn't run out of options. Now, VRP is modelling routes in such a way that either only the 08 - 12 times are being used or the 13 - 15 times. In practise, it is giving me solutions in which 1. the truck is idle for part of its working day and 2. the collections last more days than necessary (which I concluded by comparing my Route Analysis results with VRP's).
I would like to prioritise routes in such a way that it first fits the collection points into the first pair of routes (08 - 12, 13 - 15, with break) and then the second and third pairs if necessary, but I can't find a field for something like that. Route names have to be unique and I can't assign two starting and ending times. In other words, VRP needs to understand that Routes 1 and 2 are a single working day and one part of the pair can't be ignored.
How would I go about solving this?
Thank you in advance!
HeatherMoe
This can be modeled using just a single route for the day and adding in a break for the route. If the break needs to start at exactly noon the you can use the time window fields for the break and indicate both TimeWindowStart and TimeWindowEnd as 12:00 pm and a 1 hour ServiceTime.
HeatherMoe
Barbara_Araujo
Hello Heather, thank you for your reply! Indeed, once I dedicated more time to looking at my sheet I could see the redundancy. I am a beginner at GIS in general so I apologise for the simple question and solution. Further optimisation to limit the number of routes can maybe be achieved by setting a high FixedCost like you mentioned in my other thread.
