Calculate Shorter Route of Point Feature Class
1299
12-17-2013 01:10 PM
HugoSilva
Hey Everyone. I need to calculate the shorter route for going through all of my points in a Point Feature Class I have. However, I can't seem to work anything out. Network Analyst isn't working properly. Is there an easy and faster way to do this? Thank you for all your suggestions
DanPatterson_Retired
The shortest path through a set of points is their Euclidean Distance represented by a Spanning Tree
http://www.arcgis.com/home/item.html?id=6ce9db93533345e49350d30a07fc913a
If you need to follow a network path, then the Network Analyst is your choice
