Batch Routing and Creating Directions Output
3590
05-17-2013 07:06 AM
MichaelGlassman2
I have a large university dataset of handicap routes. I am trying to create separate routes and directions for every possible combination of start and end points. I have 298 locations which leads to over 88,000 possible routes. I have an ArcPy script set up to run this and it works but if it continues are its current progress I am looking at a run time of about two months.
import arcpy
from arcpy import env
env.workspace = "C:/Users/zx52530/Routing/BestTest.gdb/"
env.scratchWorkspace = "C:/Users/zx52530/Routing/BestTest.gdb/"
env.overwriteOutput = True
i = arcpy.SearchCursor("HC_2013_ND_Junctions")
... for j in i:
...     whereClause = ' "OBJECTID" = ' + str(j.OBJECTID)
...     for g in i:
...         arcpy.na.MakeClosestFacilityLayer("HC_2013_ND", "CF_" + str(j) + "_" + str(g), "Length")
...         arcpy.SelectLayerByAttribute_management("HC_2013_ND_Junctions","NEW_SELECTION",whereClause)
...         arcpy.na.AddLocations("CF_" + str(j) + "_" + str(g), "Facilities", "HC_2013_ND_Junctions")
...         whereClause2 = ' "OBJECTID" = '  + str(g.OBJECTID)
...         arcpy.SelectLayerByAttribute_management("HC_2013_ND_Junctions","NEW_SELECTION",whereClause2)
...         arcpy.na.AddLocations("CF_" + str(j) + "_" + str(g), "Incidents", "HC_2013_ND_Junctions")
...         arcpy.na.Solve("CF_" + str(j) + "_" + str(g),"SKIP","CONTINUE")
...         try:
...             arcpy.na.Directions("CF_" + str(j) + "_" + str(g),"HTML","C:/Users/zx52530/Routing/" +"CF_" + str(j) + "_" + str(g)+".txt","Feet","NO_REPORT_TIME")
...         except:
...             print "CF_" + str(j) + "_" + str(g) + "FAILS"
...             arcpy.management.SaveToLayerFile("CF_" + str(j) + "_" + str(g),"CF_" + str(j) + "_" + str(g),"RELATIVE")
...         print "Finished Facility: ", j, "to Incident: ", g
Does anyone have any ideas about how I might improve the efficiency of this script?
