Allow Location-Allocation to determine optimal locations for Existing Facilities?
8449
18
10-07-2015 09:34 AM
LarryGaudieri
I am performing a series of analysis for our county's fire rescue. One question asked was it possible for me to allow Location-Allocation to determine the best locations (from existing facilities) to meet a data set of existing demand ( a year's worth of incident responses)?
I wasn't completely sure if it was possible or how the work flow would be. Again, taking existing fire stations, can Location-Allocation move those facilities to optimal locations to better meet the demand of the incidents?
Thanks to anyone who can help me out...
JaySandhu
It sounds like you are asking what is the best location for my fire stations based on where the incidents are happening. So in that case simply make up evenly spaced candidate facilities and solve for the same number of existing fire stations. Once you have a new solution you can closest facility to find the closest new facility from the existing ones and that will give you can idea how far to move! If it is under a certain threshold you could ignore the move.
If this is not your intended use case then clarify it a bit more.
Jay
MitchHolley1
Well, if you have an incident point layer, you could do a hot-spot analysis showing where the most of the incidents occur.  From there you could do a network analysis on a road layer determining how far each fire engine could go from the fire station within __ minutes (need to determine specific amount of time).  Then analyze the results to see if any fire stations could be moved, or another one built, to better served the needed areas.
Did I understand the question correctly?  I hope this helps.
LarryGaudieri
Mitch,
Thanks for the response. Yes, you understood exactly! I have a kernel density raster of the over goal times and have those stations isolated in or surrounding those hot spots. I've also performed service area analysis using the NavStreets network.
In the manual sense you described (which is a pretty good idea), I could do that. However, to demonstrate that the moves would in fact alleviate demand in certain locations in a repeatable process to support their position in a budget year...I'm hoping ArcGIS can do it faster and more accurately.
We have 44 stations and I could shift them (or at least the problematic ones) but I might detract performance or make it worse and that could get me into a game of hunt or peck for the best result. If there's no other statistical process then your idea would be the best bet.
Thanks again!
ChrisDonohue__GISP
Adding ESRI Network Analyst ExpertMelinda Morang to this thread.  I suspect she has advice on this.
Chris Donohue, GISP
LarryGaudieri
Thank you Chris...it would be good to get as much feedback as possible.
JaySandhu
Jay
LarryGaudieri
Thanks for the response Jay. Was beginning to think no one would respond. Your solution sounds logical but could you just clarify one part?
"solve for the same number of existing fire stations."
Does that mean that when the candidates are set, solve based on the required existing stations?
The rest is clear and once you reply, I'll set it and go.
Thanks again.
JaySandhu
Location-Allocation does not "move" an existing facility. It chooses the best set from a larger set of facilities. So having a good candidate set is important. And you can choose to load in the existing fire stations as candidates (not required). If you set them as required then the same location will be chosen. But if you set them as candidate and solve then you may get some original locations chosen (meaning they are in optimal location).
And you solve for the number of fire stations you want. If you had 10 existing and you still want 10 then solve for 10.
This is a very subjective decision as slight change to the problem setup can give you a different set of "optimal" locations. So in case you end up suggestions to move, you still have to evaluate how much "better" service/response time you will get. So you should solve with the existing fire stations and then solve for moving them and compare. All LA helps you with is generate alternatives that you need to evaluate in the context of some larger goal.
Not sure if I answered your question!
Jay Sandhu
LarryGaudieri
Yeah you did...it's excellent Jay. I really appreciate it. So, it's really
2 analysis: 1 with LA, the other with CF. Ok, if I send questions as I move
thru it?
Thanks again man..
JaySandhu
Definitely ask more that is not clear!
As I said before, you can generate many alternatives. e.g. what if I have the budget to move only two? Which two?
What If I only want to cover 95% of the population in 3 minutes, how many fire stations do I need? Hint: use market share.
So get comfortable with using LA and looking at it's results. You may or may not want to use Closest Facility with 1 closest, you could look at 2 closest and pick the better one...
Jay Sandhu
