Navigator Mobile Application Map Title issue
834
09-05-2018 03:52 AM
NavigatorPOI
This is with regards to Navigator mobile application, I have created a mobile map package and shared it to Navigator. This map is an updated version of an existing older map, but with a slight change in the title (The change being small "s" is used instead of capital "S"). After the map is published and ready for download, it appears with the title as specified at the time of sharing. But, after map is downloaded, the title of the said map changes on its own to the older version of title (i.e with capital "S"). Can you please help us on what the issue could be?
Tags (1)
by Anonymous User
Not applicable
Hey Navigator POI‌,
Once the MMPK is downloaded on the device, Navigator will use the information that is internal to the Mobile Map Package. This means you'll see a different title once downloaded if the title specified at creation differs from that of the item Online. Can you verify that the Title you gave the MMPK when publishing is the same as that of the Portal item?
MarkBockenhauer
In addition to what Joel said... you may also want to use the New (for Pro 2.2) Share -> Mobile Map  user experience.  The Name and Title are the same in this UI.
