Hi! If I use my own dataset to build a navigation map, each time my data gets updated I must rebuild the navigation map in ArcGIS Pro (included Address Locators) and upload it as a mmpk on AGOL, right?
594
12-27-2017 09:24 AM
RoxanaNazarie3
Hi! If I use my own dataset to build a navigation map, each time my data gets updated I must rebuild the navigation map in ArcGIS Pro (included Address Locators) and upload it as an mmpk on AGOL, right?
MarkBockenhauer
If you want your Navigator users to have the most current version of your map (network dataset) - Yes. You will need to re-build it and share it using ArcGIS Pro.
