unregister ArcGIS server - ArcGIS Monitor - "A duplicate was found - Operation cannot proceed".
679
08-03-2024 07:35 AM
NaveenK
Hey Guys,
I tried to unregister ArcGIS server component. It has removed all the ArcGIS server services but not the actual ArcGIS server component. It does not allow the re-register the same ArcGIS server again and comes up with error message - "A duplicate was found - Operation cannot proceed".  How to get it completely cleaned-up?
Naveen
Tags (1)
Doga_SEZER
Hi NaveenK,
If you clean all the usage reports from */arcgis/admin/usagereports, it would work. When I face with that problem it worked for me.
NaveenK
Thanks @Doga_SEZER
I tired removing it again after couple of hrs later and it removed.
