SQL Server required privileges to capture Geodatabase Metrics
126
3 weeks ago
B_Franey
What are the SQL Server required privileges to capture Geodatabase Metrics? We have registered an Enterprise Geodatabase that is getting DB metrics just not Geodatabase Metrics.
StevenBeothy
Hi ArcGIS Monitor's help states:
  • A SQL Server-authenticated user account must be used to register the database for monitoring and must be mapped to the database and be granted the View server state permission on the database instance. To monitor a geodatabase, the SQL Server user account's default schema must be the same schema in which the geodatabase system tables are stored.
I like to register the geodatabase with the sde administrator credentials so to collect all of the Geodatabase metrics in this link.
