run ArcSoc Optimizer batch file
885
06-03-2021 04:47 PM
NickXu
I tried to run ArcSOC optimizer from dos command by calling test.bat; however, I got error:
06/03/2021 04:43:05 PM INFO: root: Arguments.py
06/03/2021 04:43:05 PM INFO: root: mode: list
06/03/2021 04:43:05 PM INFO: root: agsTokenURL: https://vanmappubdev.vancouver.ca/portal/sharing/rest/generateToken
06/03/2021 04:43:05 PM INFO: root: agsUser: adminUser
06/03/2021 04:43:05 PM ERROR: __main__: <urlopen error [WinError 10054] An existing connection was forcibly closed by the remote host>
06/03/2021 04:43:05 PM ERROR: __main__: None
File "urllib\request.py", line 1342, in do_open
File "http\client.py", line 1255, in request
File "http\client.py", line 1301, in _send_request
File "http\client.py", line 1250, in endheaders
File "http\client.py", line 1010, in _send_output
File "http\client.py", line 950, in send
File "http\client.py", line 1424, in connect
File "ssl.py", line 500, in wrap_socket
File "ssl.py", line 1040, in _create
File "ssl.py", line 1309, in do_handshake
ConnectionResetError: [WinError 10054] An existing connection was forcibly closed by the remote host
Do I miss some configure to run the test.bat?
Thanks!
Nick
NickXu
Hi all,
I should clarify my question. We have ArcGIS enterprise installed on Azure, and we can't monitor process and system information from ArcGIS monitor. So I try to run the batch file from azure vm to get optimization information of ArcSOCs. I know this is an extension of ArcGIS monitor, so my question is that is it possible to run the ArcSOC optimizer batch file without installation of ArcGIS monitor?
Thanks!
ReeseFacendini
Esri Alum
I don't think any of the extensions are meant to be run outside of the ArcGIS Monitor system, because there are dependencies within the software the extensions look for when running.
