Monitor service flips between start and stop, post Upgrading Monitor from 2024.1 to 2025
297
07-18-2025 04:21 AM
SatishNaik1
We have upgraded Postgres SQL DB to 16.8 successfully after that we have upgraded ArcGIS Monitor from 2024.1 to 2025 post which the monitor service starts / stops immediately.
Has any one faced similar issue and how do we fix the Monitor service start and stop issue.
CodyPatterson
MVP Regular Contributor
Hey @SatishNaik1
It appears that this is current a bug, and is currently under ESRI review, you may want to follow some of the troubleshooting steps here to verify that it's a similar issue, if not, then post your results and I'll check it out!
https://community.esri.com/t5/arcgis-monitor-questions/monitor-2025-agent-service-not-starting-on-se...
It would also be best to open up a support ticket so ESRI can gather further examples and investigate what could be going on as well!
Cody
SatishNaik1
@CodyPatterson --Sure will go through some of the workarounds. If nothing works... will surely raise a Ticket with ESRI.
