Monitor 2024.0.1 with Agent 2024.02 - register ArcGIS Server component
642
12-12-2024 10:48 AM
AntheaTung
Current have Enterprise 10.9.1 with federated ArcGIS Server sites.
Have installed ArcGIS Monitor 2024.0.1 with Agent 2024.02 on the ArcGIS Monitor machine.   Then proceeded to install Agent 2024.02 on the four ArcGIS Server machines that make up one site.
Successful at registering the Agent on the four machines and they are seen as Hosts in the Components page with their respective IP Addresses.
I have deleted one  usage report that has numeric file name  in ArcGIS Manager Admin page already.
When I try to Register Component by selecting one of the four ArcGIS Server machines (Hosts) and choose ArcGIS Server, I entered the ArcGIS Server site admin and password and tt erred with the following:
Log Details
Level
Warning
Time
12/12/24, 06:35 PM
Code
E_VALIDATION_FAILURE
Message
Validation Exception
Resource
api:/arcgis/auth/self/updateProfile
Details
settings.tables.components.0.visible: required validation failed on settings.tables.components.0.visible, settings.tables.components-arcgis_server.0.visible: required validation failed on settings.tables.components-arcgis_server.0.visible, settings.tables.components-arcgis_portal.0.visible: required validation failed on settings.tables.components-arcgis_portal.0.visible, settings.tables.components-host.0.visible: required validation failed on settings.tables.components-host.0.visible, settings.tables.components-service.0.visible: required validation failed on settings.tables.components-service.0.visible, settings.tables.components-storage.0.visible: required validation failed on settings.tables.components-storage.0.visible, settings.tables.logs.0.visible: required validation failed on settings.tables.logs.0.visible, settings.tables.metrics.0.visible: required validation failed on settings.tables.metrics.0.visible, settings.tables.metric-registry.0.visible: required validation failed on settings.tables.metric-registry.0.visible, settings.tables.notifications.0.visible: required validation failed on settings.tables.notifications.0.visible, settings.tables.observers.0.visible: required validation failed on settings.tables.observers.0.visible
ID
Process
5140
Trace ID
cm4lnsz9r0235ysp00f327xka
Client IP
127.0.0.1
Machine
S-L_AGSMonitor
Username
siteadmin
Time elapsed
18
Payload
null
Anthea
AntheaTung
I am able to register the ArcGIS Server component.  Must be the FQDN and the site admin logins.
BrettFrahm
I'm seeing the same issue. Currently working with ESRI support and hope to find an answer at somepoint.
