Incorrect ArcGIS Monitor Data Expression Results for Portal's Total user count & Active user count
377
06-19-2024 02:31 AM
PrathameshDa
We're encountering an issue with data expressions in ArcGIS Monitor. When calculating the total number of users and active users within our portal, we're receiving inaccurate results.
Here's a breakdown of the issue:
  • Data Expression: We're using a data expression to determine the total number of users. This expression includes:
    • Type: Portal for ArcGIS
    • Identifier: user_total
  • Second Data Expression: Another data expression is used to find the total number of active users. This expression utilizes:
    • Identifier: user_total:active
Unexpected Results:
  • The user count retrieved from both expressions appears incorrect.
  • The active user count is higher than the total user count, which is illogical.
However, data expressions for portal items, maps, and layers function as expected and return accurate counts.
Additional Information:
For your reference, I've attached screenshots that further illustrate the issue.
We would greatly appreciate your assistance in troubleshooting this discrepancy and ensuring the data expressions provide accurate user counts for both total and active users within the portal.
PrathameshDa
By adding additional data expression issue has been resolved
DavidColey
Hello @PrathameshDa
You may need to set up an additional metrics join to report the number of users within the past hour or so.  This is what I use:
Look for @DerekLaw 's posts here in this space.  He has put up some expressions to help get counts like this for various analysis components....
ChrisBerryman
New Contributor III
I use this same expression, and we get much higher active users than there should be.
DerekLaw
Esri Esteemed Contributor
Hi @ChrisBerryman,
FYI, the number of active users metric shows the number of portal members who have logged into the Enterprise portal in the last 30 days.
How are you determining the "expected" number of active users in the last 30 days?
DerekLaw
Hi @PrathameshDa,
Can you please post screenshots of the data expressions you've configured to get the results shown?
PrathameshDa
