Hi All,
ArcGIS Monitor & Agent 2024.1.1+704.
I am not able to view any log data for any registered components. I am able to register agents and components successfully as well as run the associated log observers without errors. I also verified that there are partitions are being created in the monitor database table component_logs, and that these tables are empty.
Is there additional setup that needs to be done to capture the logs?
Hi Derek,
Yes, under Monitoring > Components > Selected Component > Logs Pasted image 20250703155926.png
I also tried checking that the logs observer was enabled on the agent.
A day later the logs entries have started to populate and it seems to be working as expected.
Thanks!
Hi @Justin0001,
No, there is no additional configuration. The logs should work after Monitor is installed.
Can you please elaborate? Under the Monitoring tab > select a component > Logs sub tab - do you see a list of logs? or something else? can you post a screenshot?
If you see a list of logs, click View details on one of them - what do you see? can you post a screenshot?
Hope this helps,
Hi Derek,
Thanks!
Hi @Justin0001,
I'm glad to hear this.
