Love that actual email alert info has been added back in with 2024.1, but we are now getting alert emails at regular intervals that can't be reconciled to actual alerts in Monitor. They look like the following with no component information and "Invalid DateTime" being the bogus alert signature. Anyone else experience this or have additional info?
ID | OPENED AT | CLOSED AT | STATE | STATUS | ALERT RULE | COMPONENT NAME | COMPONENT ADDRESS_INTERNAL | COMPONENT TYPE - SUBTYPE | METRIC NAME |
371 | Invalid DateTime | Invalid DateTime | Resolved | Critical | Average < 100 |
hi,
When you receive the email, the subject line will include the notification name, and it should also reference the subscribed event name that triggered the email.
This information can help you locate the notification and fine-tune it.
However, I should mention that, in my case, the triggers are not firing the same way as they did before the upgrade. Here’s how it appears in my system:
All,
Can you please contact Esri Tech Support so they can investigate further and reproduce the issues you're encountering? Thanks.
We are experiencing a very similar problem in our environment (presumably since switching to the new ArcGIS Monitor version 2025.1.1): we regularly receive email notifications at 1:15AM with “Invalid DateTime” and empty information about the components and metric name.
@DerekLaw Is this a meanwhile known issue? Or should we open a support case?
Hi @Tobias_Gerber,
Please contact Esri Tech Support and open a case. It will help if you can provide steps to help reproduce the behavior. Thanks.
