ArcGIS Monitor SMTP Encryption
232
08-26-2025 11:17 AM
B_Franey
When configuring the SMTP settings for ArcGIS Monitor. Just confirming, you only get the Encryption method drop-down arrow if our SMTP server requires an encrypted connection? Otherwise, there is no longer a drop-down choice.
2 Solutions
CodyPatterson
MVP Regular Contributor
Hey @B_Franey
What version of Monitor are you using? I'm using 2024.1 and I see this here prior to me entering anything:
Are you seeing this by default or is this not appearing for you?
I'm seeing in these release notes at the bottom: https://support.esri.com/en-us/patches-updates/2025/arcgis-monitor-2025-0-release-notes
BUG-000176247: Encryption Method drop-down missing in Configure Email Settings window in ArcGIS Monitor 2024.1.1
Which seems to be addressed in the 2025.0 and 2025.0.1 updates respectively.
Cody
B_Franey
Hi Cody,
Yes, the ArcGIS Monitor version is 2024.1.
There is no dropdown. Thanks for sharing the bug and workaround.
Bryan
CodyPatterson
Hey @B_Franey
Cody
B_Franey
Hi Cody,
Bryan
