ArcGIS Monitor 2023.3 - does it support Azure SQL Database
879
12-21-2023 07:07 AM
AntheaTung
New Contributor III
Hi All,
Have downloaded the ArcGIS Monitor 2023.3 and applied this upgrade.  For this release, it states supporting SQL Server components.  I tried to connect to Azure SQL Database using instance name  ppp-xxxx-gissavy.database.windows.net:1433, ppp-xxxx-gissavy.database.windows.net, internal IP Address of this instance and these tests gave this error : cannot process request for specified agent.
I tested connecting using SQL Server Management Studio and it works (using ppp-xxxx-gissavy.database.windows.net).
Question:  does this release support Azure SQL Database?
Thank you
Anthtea
GeoJosh
@AntheaTung,
I believe this should work. Can you submit a case with support so we can dig deeper into what's happening?
Josh
AntheaTung
New Contributor III
@GeoJosh  will do - thank you
