Hello ArcGIS Monitor Team,
Please add the ability to filter and sort by Label. Currently this functionality is not in the 2023.2
Not listed in filter:
Not listed in Sort:
Not listed on the field:
Thanks for your consideration,
Amanda Huber
Hi @Amanda__Huber,
FYI: Please select the label(s) you would like to "sort" or "filter" on - by selecting the desired label(s) under the "Labels" button (which is located to the left of the "Sort" button in the UI. Then apply the desired "sort" or "filter". I think this is what you're asking for.
If not, can you please clarify what you would like to do?
Hope this helps,
Thanks for the quick reply! Ah that makes sense, totally missed that option (not the first place I would have intuitively looked). Thank you!
