Discover ArcGIS Monitor 10.6.1
6448
10
07-05-2018 12:33 PM
ShreeRajagopalan
ArcGIS Monitor 10.6.1 includes new features and enhancements to make you more productive. Here’s what you can do:
Alerts filtering with links
Quickly filter and sort open or closed alerts with links to charts, statistics, and in some cases log details, or the source url. With one click, you can access severe or warning log entries for ArcGIS Server.
Explore Demo Site > Alerts tab
View current status icons
Use high-level status icons to quickly communicate collection status for managers. A count of healthy and unhealthy collections and count of alerts also help summarize the status more efficiently.
Explore Demo Site > Home tab
View availability status icons
Use high-level icons to quickly communicate the count of collections where availability is less than 99%. This allows administrators to focus on areas where availability was lowest for a time range.
Explore Demo Site > Availability tab
Monitor ArcGIS GeoAnalytics Server
When using GeoAnalytics Server, view new counters including status, cores, and memory for Workers in the GeoAnalytics tab.
View Health Check counters
Quickly check the Health Check counter for a site obtained directly from the ArcGIS REST API. A Health Check counter was added for both ArcGIS and Portal counter types in the Categories > ArcGIS report. A value of zero indicates the site level url is healthy and a value of 1 indicates the site is unhealthy. The Health Check counter is separate from ArcGIS Server logs. A site url may be healthy but have service level errors in the logs.
Use Windows authentication for ArcGIS, Portal, and Http counter types
Conveniently use credentials of the Windows administrative users in the ArcGIS Server built-in store or Active Directory to authenticate for ArcGIS, Portal, and Http in both federated and non-federated environments. Secured ArcGIS Server services requiring a token can also use Windows authentication if the Windows user that is running the ArcGIS Monitor Service has authorization to access the target site or service. Either ArcGIS Server authentication or Web Tier authentication can be configured.
View International dates and number formats
Internationalization support was added for date, time, and number formats to improve the usability for international environments. Unicode support was added for the installation, configuration, and data viewing of non-English usernames, passwords, labels, and input text.
Lastly, 6 new videos are available for ArcGIS Monitor 10.6.1:
  1. ArcGIS Monitor Demo for Managers
  2. ArcGIS Monitor Demo for Administrators
  3. Understanding Availability
  4. Add Portal
  5. Add ArcGIS Server
  6. Add Http
Questions? Comment below and we'll get back to you soon!
10 Comments
About the Author
I manage marketing strategy, communications and product marketing for an elite group of products at Esri. I also help draft/refine messaging and artifacts, and promote awareness, demand and adoption among Esri customers.
