ArcGIS Monitor: Exploring the Check-Service Observer
186
2 weeks ago
DerekLaw
Esri Esteemed Contributor
2 2 186
At the ArcGIS Monitor 2024.1 release, a Check-Service observer was introduced. This observer allows a Representational State Transfer (REST) request to be configured against a registered service component, which enables admins to apply requests to monitor a variety of scenarios.
This blog discusses 3 example use cases for using the Check-Service observer to apply some simple health and performance tests against a service component. The use cases are:
  1. Test to check features in a feature service
  2. Test response time for an export map operation on a map service
  3. Test for a specific response from a feature service (to check data integrity)
The intention is to illustrate the potential of the Check-Service observer to help admins test health and performance of Monitor service components.
2 Comments
ChaseBarnard
I’m interested in using the Check-Service observer to alert me when a service(s) go down. Am I correct in assuming that in order to do that, you would need to configure the observer with each REST Service component individually?
DerekLaw
Hi @ChaseBarnard,
Yes that is correct.
EDIT: alternatively, please take a look at this thread, ArcGIS Monitor 2025 - does it report mapservice crashing
And you can batch configure alerts for the same component types.
Hope this helps,
Contributors
About the Author
Senior Product Manager - Twitter/X | Mastodon | Bluesky : @GIS_Bandit
