S-57 Data
4038
09-11-2019 11:45 AM
MrinmayeeBharadwaj
Need Nautical Chart Data in Your Map?
There are a wide variety of ways in which you can leverage nautical charting data in ArcGIS Desktop, where the best method depends upon your unique needs.
If you just need to bring S-57 data into the desktop for visualization, the Esri S-57 Viewer is a lightweight and easy to use option that provides basic viewing capabilities in ArcMap. A link to the free S-57 Viewer can be found here.
If your needs go beyond simply viewing S-57 datasets, and you need the data in a geodatabase for GIS analysis, editing, or other data manipulation, then you can leverage the capabilities in the ArcGIS for Maritime: Charting extension, where there are scriptable tools for both importing S-57 datasets into the geodatabase and also for rendering them with ECDIS-like symbology. S-57 to GIS is a python script tool available on GitHub that automates the process of ingesting S-57 into the geodatabase and symbolizing it with S-52.
Lastly, you can also consume S-57 as a service directly into the Desktop - ArcMap or ArcGIS Pro, through web-based solutions like NOAA ENC Online.
For more information about how you can leverage nautical chart data in ArcGIS Desktop for purposes beyond navigation, please contact us at [email protected]
2 Comments
Warwick
Does the S-57 to GIS script  (https://github.com/Esri/maritime-charting-sample-scripts/tree/master/S57%20To%20GIS) work in ArcMap 10.8.1?
CraigTGreene
This script was last updated for 10.5.1. It is possible that you may need to update some of the templates.
You can try to use it on 10.8.1, and if it does not succeed, there are manual steps we can step through to achieve the same result. You only have to perform these manual steps once, and you can reuse the templates you create from that manual process.
If you have access to ArcGIS Pro, this is also simplified a bit further, although the best solution for you depends on your end goal.
If you would like to discuss further, you can reach out to us directly at [email protected]
Thanks - Craig
