Hold down mouse wheel until cursor changes to roam in ArcGIS Pro and Runtime .NET
4030
7
10-09-2019 03:20 PM
Status: Open
MarkCederholm
It would be nice to have click and hold down the mouse wheel until the cursor changes to roam functionality in ArcMap to be implemented also for ArcGIS Pro and Runtime .NET.
7 Comments
KoryKramer
Mark, what tool do you have active?  With the Explore tool active, it isn't necessary to depress the mouse wheel to pan.  You can pan by holding the left mouse button.  If you have another tool active, like Select, then depressing the center mouse wheel does pan.
MarkCederholm
That's not the same.  If you were an ArcMap user you'd know what I was talking about.
NickDierks1
Kory, If you check out the video Mark uploaded, you'll see he's asking about holding the wheel down until the other pan functionality kicks in, moving in the direction you gesture. This is similar to scrolling a webpage up and down by holding the wheel button.
That said, I never understood why the default pan functionality you're showing disables the wheel click while using the Explore tool. It works with all tools in ArcMap, including when Pan tool is active. It's just a weird habit to use one click for 80% of situations, but suddenly switch to a different click for the remaining 20%. The wheel click isn't used for anything else with the Explore tool active, is it?
KoryKramer
1. There was no video attached when this was submitted.
2. I've used ArcMap for more years than ArcGIS Pro and find your comment insulting.
MarkCederholm
Sorry about that.  I would have attached the video to a comment if I could have.
KoryKramer
It looks like you're talking about roam, not pan.
Keyboard shortcuts in ArcMap—Help | ArcGIS Desktop
I'll change the title of your idea so that it reflects what you're requesting.
Currently, holding Q works the same in ArcGIS Pro.
Keyboard shortcuts for navigation—ArcGIS Pro | ArcGIS Desktop
I can't speak to the Runtime part of your idea.
KoryKramer
Nick Dierks‌ We just moved https://community.esri.com/ideas/17748 to In Product Plan!
