Unity Maps SDK Questions
117
2.9M
335
| Open | Hi guys, Do you have any plans to add similar features that support dynamic mesh to draped on ArcGIS maps.Best,Chengf... by chengfang-dong Occasional Contributor 0 0 | 0 | 0 | |
| Open | Hi,It would be great if support for locally placed web tiled layers is added just like in arcgis runtime for .NET, JA... by TasawarAhmad Occasional Contributor 1 0 | 1 | 0 | |
| Open | My original goal was to create a voxel visualization in mixed reality with the HoloLens 2.My plan was to create a vox... by zdgra Regular Contributor 1 0 | 1 | 0 | |
| Open | It would be great if you could assign a Unity Layer to the rendered map so that it could selectively render or handle... by MBambino_ATS Occasional Contributor 1 0 | 1 | 0 | |
| Implemented | I am working on a project where we need two maps present in the scene at a time. That is currently not supported in M... by JakobHougaardAndersen Emerging Contributor 2 2 | 2 | 2 | |
| Open | ArcGIS Pro is great to view Point Cloud files in them. However, the scene layers that can be created thereafter are n... by brollsroyce_tek Emerging Contributor 0 1 | 0 | 1 | |
| Open | Would be nice to have an option to select huge area or even the whole world created from ArcGis maps SDK with all lay... by MNM Emerging Contributor 0 2 | 0 | 2 | |
| Open | Add Lidar data layer support to represent laser scanned data from the real area and a possibility convert lidar point... by MNM Emerging Contributor 1 0 | 1 | 0 | |
| Open | I like building Unity applications for WebGL so I can build the UI in a web-application that imports the Unity WebGL ... by ErikWB Emerging Contributor 3 1 | 3 | 1 |
Idea Submission Guidelines
