Visualize 3D object ID (Hit Test)
897
10-27-2024 01:20 PM
AmalSivaMundakkalSadasivan
Hello,
I tried performing a hit test using the ArcGIS SDK by adding an ArcGIS Raycast, Static mesh, and BP feature ID from the samples folder to my map. However, when I ran the level , the hit test doesn´t work. I also attempted the same setup at the exact location specified in the sample level, but it still didn´t work. I am using unreal engine 5.4 and ArcGIS SDK version 1.6. Additionally other levels in the sample folder such as ´´Line of sight´´ and ´´material by attribute´´ are also not working when I play their levels, although they work correctly in the Sample Viewer level.
MasonGaw
Hello,
please follow this guide for migrating content from one project to another. Please keep in mind that the samples are not designed to be migrated over and could have issues when migrating due to references to other files within the sample project. If you continue to have issues getting them to work in your own project, please copy and paste the necessary blueprint nodes from the individual files into your own blueprint files in your project.
Mason
