Unreal Engine crash when using the SDK
658
05-12-2026 09:32 AM
Fishy1996
I want to use Unreal Engine 5.7.4 in combination with ArcGIS SDK version 2.3.0. When I follow this tutorial (https://developers.arcgis.com/unreal-engine/install-and-set-up/),  Unreal Engine crashes the moment I want to create the map.
I also tried the combinations:
- UE 5.7.4 -> ArcGIS SDK v2.2.0
- UE 5.6.1 -> ArcGIS SDK v2.3.0
- UE 5.6.1 -> ArcGIS SDK v2.2.0
All have the same issue. I have attached the log files, hopefully someone knows how to solve this.
and1
by Esri Contributor
There appears to be a conflict with the GeoreferencingSystem actor in this Simulation template. After removing that, a Map can be created successfully.
We had a fix for this and it will go in for version 2.4. For now, we would recommend you either remove the GeoreferencingSystem actor before creating a map or just use the Blank template instead. Thanks!
and1
by Esri Contributor
Hello @Fishy1996 , were you using the Simulation blank template by any chance?
Fishy1996
Yes, exactly that one! I want to use it to make a simulation over the tiles. That's why I chose it.
and1
by Esri Contributor
