How to set the vertical coordinate system
831
11-22-2022 11:58 AM
shahbaar
I am trying to use an elevation layer where the height values are in feet. What's the correct way of setting the VCS?
Currently, using level blueprint, I 'Create ArcGIS Spatial Reference Vertical WKID' at begin play and use that to create a point with XYZ spatial reference and assign that point as the origin of the map actor. The horizontal CS seems to take effect but the VCS doesn't seem to have any effect, and the WKID of the VCS of the origin is still 0. I have tried multiple WKIDs and none of the seem to work.
