Can UE widget UI set variable values in ArcGIS
327
06-02-2026 01:33 PM
HQsimwerx
Can UE user set variable values in ArcGIS. UE UI is a widget where user inputs values for ArcGIS to do a type of map or function. For example, user wants to go to a certain coordinate or set map scale.
AShahbaz
Yes, but you would need to implement the UI or user interaction to call the appropriate API. Our samples have several examples of UIs that allow the user to make changes to the map/level or perform analysis.
