Can i get BIM in ArcGIS Building Scene Layer Components?
403
12-19-2023 01:19 AM
NhaNguyenDinh
I would like to inquire if there is a way to display BIM through the components of the ArcGIS Building Scene Layer or to change its materials. With the newly released version 1.4, the components are now interactive. If not, Do you have any plans or strategies for implementing this in the future? Thank you!
DA_BIM-GIS
If I understand correctly your question. You want to add additional data (elements) to the BSL? That is not possible if you are using building scene layer package, but If you leverage the hosted feature layer workflow you will be able to edit the BSL (add\delete and edit)
David
