Blueprint tabletop | example tutorial
602
04-22-2025 06:23 AM
AlperAL
Dear all,
It is great to be here. I am just a beginner. I set up the ArcGIS Maps SDK for Unreal Engine. I followed the instructions from 'tutorial blueprints' to create a tabletop scene. Even though everything looks the same when I hit play, I only see a blue globe, without any earth features. However, when I exit Level Blue Print, I can see and navigate the normal world map. I would be very happy if you could help me with this.
AShahbaz
It is difficult to tell without further details, but you could verify that the arcgis pawn/camera is located at the correct location and looking toward the globe.
The fog and atmosphere sometimes cause issues too so you might want to disable them. Also make sure the (directional) light has the correct angle.
Tabletop maps can be more involved to make, so I recommend getting familiar with the plugin with simpler scenarios before creating a tabletop setup. In case you didn't notice, there is a tabletop sample in flat-earth mode provided along with the plugin under "...\ArcGISMapsSDK\Content\Samples"
