Problems loading custom elevation layers and IntegratedMesh data
971
10-31-2025 06:24 AM
ChristofferLindellBolin
In the latest ArcGIS maps SDK release 2.1 I am having issues loading in custom elevation data and IntegratedMesh data through C# API. It worked in prior 1.* without an issue so there seems to be a problem in the latest release. I use the following code:
Map is created as follows which is called in start:
        private void CreateArcGisMapComponent()
            GameObject go = new GameObject("ArcGISMap");
            _mapComp = go.AddComponent<ArcGISMapComponent>();
            _mapComp.transform.SetParent(transform, false);
            _mapComp.OriginPosition = new ArcGISPoint(Origin.Longitude, Origin.Latitude, Origin.Altitude, ArcGISSpatialReference.WGS84());
            _mapComp.MeshCollidersEnabled = _enableMeshColliders;
            _mapComp.MapType = _mapType;
            _mapComp.MapTypeChanged += new ArcGISMapComponent.MapTypeChangedEventHandler(() => CreateArcGISMap());
            GameObject rebaseObject = new GameObject("Rebase Component");
            rebaseObject.transform.SetParent(go.transform, false);
            _rebaseComponent = rebaseObject.AddComponent<CustomRebaseComponent>();
            if (ApplicationBootstrapper.Instance.IsDebugEnabled(typeof(TerrainManagerHostService)))
                ArcGISViewStateLoggingComponent logger = _mapComp.gameObject.GetComponent<ArcGISViewStateLoggingComponent>();
                if (logger == null)
                    _mapComp.gameObject.AddComponent<ArcGISViewStateLoggingComponent>();
        private uint CreateArcGISMap()
            uint result = Res.OK;
            List<TerrainDefinition> definitions = _parser.GetDefinitions().ToList();
            var map = new ArcGISMap(_mapComp.MapType);
            var elevationLayers = new ArcGISCollection<ArcGISElevationSource>();
            var layers = new ArcGISCollection<ArcGISLayer>();
            foreach (TerrainDefinition definition in definitions)
                result = ValidateConditions(definition, out ArcGISMapLayer layer, out TerrainSource source);
                if (Res.CheckCallFailed(result))
                    break;
                string uri = source.Uri.IsFile ? source.Uri.LocalPath : source.Uri.ToString();
                if (layer.Type == ArcGISSourceType.Basemap)
                    if (!string.IsNullOrEmpty(map.Basemap.Source))
                        LOG.Error("A basemap has already been added, multiple basemaps are not supported!");
                        result = RES.E_SERVICE_INVALID_STATE;
                        break;
                    if (layer.LayerSourceType == ArcGISLayerType.ArcGISImageLayer)
                        map.Basemap = new ArcGISBasemap(uri, ArcGISLayerType.ArcGISImageLayer, "");
                    else if (layer.LayerSourceType == ArcGISLayerType.ArcGISVectorTileLayer)
                        map.Basemap = new ArcGISBasemap(uri, ArcGISLayerType.ArcGISVectorTileLayer, "");
                    else
                        map.Basemap = new ArcGISBasemap(uri, "");
                    LOG.Debug($"Added Basemap {Enum.GetName(typeof(ArcGISLayerType), _mapComp.BasemapType)} from URL: \"{uri}\"");
                else if (layer.Type == ArcGISSourceType.Elevation)
                    var elevation = new ArcGISElevationSource(uri, ArcGISElevationSourceType.ArcGISImageElevationSource, "");
                    elevationLayers.Add(elevation);
                    LOG.Debug($"Added Elevation layer from URL: \"{uri}\"");
                else
                    layers.Add(new ArcGISLayer(uri, layer.LayerSourceType, ""));
                    LOG.Debug($"Added {Enum.GetName(typeof(ArcGISLayerType), layer.LayerSourceType)} from URL: \"{uri}\"");
                return result;
            if (string.IsNullOrEmpty(map.Basemap.Source))
                LOG.Warn("Missing basemap, creating an empty basemap");
                _mapComp.Map = new ArcGISMap(ArcGISSpatialReference.WGS84(), _mapType);
            else
                map.Elevation = new ArcGISMapElevation(elevationLayers);
            map.Layers = layers;
            _mapComp.View.Map = map;
            _mapComp.Map.LoadStatusChanged += OnMapStatusChanged;
            _mapComp.View.SpatialReferenceChanged += OnSpatialReferenceChanged;
            return result;
And if i get it to load, my integrated mesh data can look like this and I need to move the camera around to get it to load:
ChristofferLindellBolin_0-1761923096412.pngChristofferLindellBolin_0-1761923096412.png
Also, another issue which bothers me is that when I update the map through C# script, these changes does not update the MapComponent in the editor.
Tags (3)
If i instead for example add the elevation source like this, it loads. So something funky is going on and it may be seperated from the issue I have with Integrated Mesh layer that in 2.1 sometimes does not render depending on angle of camera. If I downgrade to 2.0 and use the below code, everything works for me.
var temp = new ArcGISElevationSourceInstanceData
	Source = uri,
	AuthenticationType = Esri.ArcGISMapsSDK.Authentication.ArcGISAuthenticationType.None,
	IsEnabled = true,
	Type = ArcGISElevationSourceType.ArcGISImageElevationSource,
	Name = layer.Name
_mapComp.MapElevation.ElevationSources.Add(temp);
map.Elevation.ElevationSources.Add(new ArcGISImageElevationSource(uri, layer.Name, ""));
For some reason when I load an elevation layer from an offline file I need to add it to elevationsources here meanwhile if i use a elevation source from an Enterprise/ArcGIS online server I need to add it to the map.
