Map scaling different between public and local map type in Unity
1189
01-29-2024 12:18 PM
HannesBleicher
I just noticed that the scaling is way off for a map that's set to local. I was expecting one meter on the map being one unit in Unity (which is one meter). But with a local map, a meter is about 2 unity units. I was about to kick ArcGIS out of the project when I realized that this is not the case with a global map and that the scaling is correct here. Is this behavior intentional and if so, is there a way to scale a local map correctly, since I don't actually need a global one.
Thanks a lot
Hannes
mbd
