Issue adding a layer to ComponentLocal Sample scene
1387
12-28-2023 11:08 AM
ChrisRenzi
I'm trying to add a layer to the ComponentLocal sample scene.  I would like to add the OpenStreetMap 3D Buildings layer (details here: https://www.arcgis.com/home/item.html?id=ca0470dbbddb4db28bad74ed39949e25
If I remove the "San Francisco 3D Buildings" and add the source url for the "OpenStreetMap 3D Buildings" (https://basemaps3d.arcgis.com/arcgis/rest/services/OpenStreetMap3D_Buildings_v1/SceneServer) It does not render the buildings in 3D.
I've tried changing the layer type as ArcGIS 3DObject Scene Layer and ArcGIS Building Scene Layer and neither one works (none of the other types work either).  Is this just a limitation in the Unity SDK that some of these layers do not render?
I'm just trying to load buildings as basic 3D models, maybe there is a different way to do it?
ChrisRenzi
ChrisRenzi
Does anyone know if/when OSM 3D buildings layer support will be added?  If not, is there a layer that can be added to the map that will generate buildings dynamically even for ANY basic vector tile, not just for specific pre-rendered cities like the San Fran example?
