How to convert high precision location values to coordinates?
2528
05-09-2023 07:43 AM
navintc
I'm using the SampleArcGisRayCast component and I'm trying to get the coordinates (lats and longs) of the specific building that's clicked on. I managed to get their high-precision location values of them but, I don't understand how to convert them to lats and longs. Any suggestions on how to update the code in the sample to achieve this?
Jade
by Esri Contributor
updated:
var geoPosition = arcGISMapComponent.EngineToGeographic(hit.point);
navintc
This code kind of boosted how I understood arcGis SDK. But I have a follow-up question @Jade. I used your suggestion in the sampleArcGisRayCast component to get the coordinates of buildings. It seems the code line doesn't support both hit.point and location.Position. Any suggestion to get it working?
if (Input.GetKey(KeyCode.LeftShift) && Input.GetMouseButtonDown(0))
			RaycastHit hit;
			Ray ray = Camera.main.ScreenPointToRay(Input.mousePosition);
			if (Physics.Raycast(ray, out hit))
				var arcGISRaycastHit = arcGISMapComponent.GetArcGISRaycastHit(hit);
				var layer = arcGISRaycastHit.layer;
				var featureId = arcGISRaycastHit.featureId;
				DumpToConsole(arcGISRaycastHit.layer);
				DumpToConsole(arcGISRaycastHit);
				if (layer != null && featureId != -1)
					var offsetPosition = new ArcGISPoint(geoPosition.X, geoPosition.Y, geoPosition.Z + 200, geoPosition.SpatialReference);
					var rotation = arcGISCamera.GetComponent<ArcGISLocationComponent>().Rotation;
					var location = canvas.GetComponent<ArcGISLocationComponent>();
					location.Position = offsetPosition;
					location.Rotation = rotation;
// Your code snip
					ArcGISPoint latLong = arcGISMapComponent.View.WorldToGeographic(hit.point);
				else
					popUp.SetActive(false);
Jade
by Esri Contributor
hi! So with your line of code
you should be able to get lat long (if you're in global mode, if you're in local mode, you get large x,y,z value which is on the projected coordinate system).
var worldPosition = math.inverse(arcGISMapComponent.WorldMatrix).HomogeneousTransformPoint(hit.point.ToDouble3());
ArcGISPoint latLong = arcGISMapComponent.View.WorldToGeographic(worldPosition)
is another way of getting lat long, but you need to use double3 which is why hit.point doesn't work.
Deivydas24
If I'm using a local mode. Is there a way to convert a large x,y,z values to normal lat and long?
