create game object dynamically
2305
6
04-24-2023 09:15 AM
文言李
Hi all,
I had an unity project in which i create some models dynamically, but after I insert map into the project, I can't found the gameobject created by me, anyone can tell me why?
thanks in advance
jeff
mbd
Hi, I'm thinking of two possibilities:
1. the game object is not a child of the arcgismap object, then the camera doesn't show it.
2. the game object location doesn't have an arcgis location component or is position is far away the origin and extends of the map
I hope it helps!
mbd
文言李
Thank you mbd, it's really helpful.
But are all the game objects in arcgismap project be children of arcgismap?
文言李
I paste my code here as follows,
public void OnCreateCubeButtonClicked()
     Instantiate(myCube, new Vector3(0, 0, 0), Quaternion.identity);
     GameObject arcgixMap = GameObject.Find("ArcGISMap");
     if (arcgixMap != null)
        myCube.transform.parent = arcgixMap.transform;
    HPTransform hpTransform = myCube.GetComponent<HPTransform>();
    if (hpTransform != null)
        hpTransform.LocalPosition = new Unity.Mathematics.double3(-2871978.3959205807,              4132157.7468104535, -4529007.4551753243);
        hpTransform.LocalScale = new Unity.Mathematics.float3(100000, 100000, 100000);
Anything wrong?
Jade
by Esri Contributor
You didn't add the location component to your go.
文言李
No, I didn't add component HPTransform, because myCube is a prefab, and I've added the HPTransform component in the inspector.
Another problem is I set the position of hpTransform like this,
hpTransform.LocalPosition = new Unity.Mathematics.double3(-4451191.8873, 6562076.953, 1046025.930);
button when playing, the position of hpTransform is (6378137, 0, 0)
Any clue?
Jeff
WeiPin
嘿!哥们,我搞定了!需要你的Game object在ArcGISMap的层级下面,Game object需要添加两个组件HPTransform、ArcGIS Location。可以通过ArcGIS Location组件修改经纬度。
