Brand new project, Mac M1, non functioning?
2472
7
02-28-2023 01:23 AM
ARuiz
I've just downloaded and installed plugin on Mac M1 Unity 2022.1.16 and URP Version 13.1.8. I just get this error and no map render? Am I missing something? Any help appreciated!
A
DllNotFoundException: libruntimecore assembly:<unknown assembly> type:<unknown type> member:(null)
Esri.GameEngine.Geometry.ArcGISGeometry.get_SpatialReference () (at Library/PackageCache/com.esri.arcgis-maps-sdk@d1c578d68416/SDK/API/GameEngine/Geometry/ArcGISGeometry.cs:281)
Esri.ArcGISMapsSDK.Editor.Components.ArcGISPointEditor.OnGUI (UnityEngine.Rect position, UnityEditor.SerializedProperty property, UnityEngine.GUIContent label) (at Library/PackageCache/com.esri.arcgis-maps-sdk@d1c578d68416/Editor/Components/ArcGISPointEditor.cs:65)
UnityEditor.PropertyDrawer.OnGUISafe (UnityEngine.Rect position, UnityEditor.SerializedProperty property, UnityEngine.GUIContent label) (at /Users/bokken/buildslave/unity/build/Editor/Mono/ScriptAttributeGUI/PropertyDrawer.cs:23)
UnityEditor.PropertyHandler.OnGUI (UnityEngine.Rect position, UnityEditor.SerializedProperty property, UnityEngine.GUIContent label, System.Boolean includeChildren, UnityEngine.Rect visibleArea) (at /Users/bokken/buildslave/unity/build/Editor/Mono/ScriptAttributeGUI/PropertyHandler.cs:170)
UnityEditor.PropertyHandler.OnGUI (UnityEngine.Rect position, UnityEditor.SerializedProperty property, UnityEngine.GUIContent label, System.Boolean includeChildren) (at /Users/bokken/buildslave/unity/build/Editor/Mono/ScriptAttributeGUI/PropertyHandler.cs:131)
UnityEditor.PropertyHandler.OnGUILayout (UnityEditor.SerializedProperty property, UnityEngine.GUIContent label, System.Boolean includeChildren, UnityEngine.GUILayoutOption[] options) (at /Users/bokken/buildslave/unity/build/Editor/Mono/ScriptAttributeGUI/PropertyHandler.cs:283)
UnityEditor.EditorGUILayout.PropertyField (UnityEditor.SerializedProperty property, UnityEngine.GUIContent label, System.Boolean includeChildren, UnityEngine.GUILayoutOption[] options) (at /Users/bokken/buildslave/unity/build/Editor/Mono/EditorGUI.cs:10863)
UnityEditor.EditorGUILayout.PropertyField (UnityEditor.SerializedProperty property, UnityEngine.GUIContent label, UnityEngine.GUILayoutOption[] options) (at /Users/bokken/buildslave/unity/build/Editor/Mono/EditorGUI.cs:10852)
Esri.ArcGISMapsSDK.Editor.Components.ArcGISMapComponentEditor.OnInspectorGUI () (at Library/PackageCache/com.esri.arcgis-maps-sdk@d1c578d68416/Editor/Components/ArcGISMapComponentEditor.cs:133)
UnityEditor.UIElements.InspectorElement+<>c__DisplayClass62_0.<CreateIMGUIInspectorFromEditor>b__0 () (at /Users/bokken/buildslave/unity/build/ModuleOverrides/com.unity.ui/Editor/Inspector/InspectorElement.cs:651)
UnityEditor.InspectorWindow:RedrawFromNative() (at /Users/bokken/buildslave/unity/build/Editor/Mono/Inspector/InspectorWindow.cs:175)
MichaelBranscomb
Esri Frequent Contributor
Support for developing with the silicon version of the Unity Editor and deploying to Apple silicon is now available with ArcGIS Maps SDK for Unity v1.2 - Announcing ArcGIS Maps SDKs for Game Engines 1.2 (esri.com).
DanPatterson
MVP Esteemed Contributor
ARuiz
Thanks for the rapid reply, will try that!
and1
by Esri Contributor
Hi, at the moment we do not support M series chips yet. However, you can download the Intel version of Unity, and when you want to build out a macOS application, make sure to select the Intel 64-bit from the drop-down list for the Architecture option in the Unity Build Settings window.
More info can be found in the System Requirement page and Deployment page of the doc.
MichaelBranscomb
chenqiangNJ1992
I also encountered this problem, using unity on windows, unity switching to linux  and using arcgis for unity version 1.7.0,   DllNotFoundException: libruntimecore.so assembly:<unknown assembly> type:<unknown type> member:(null)
德强舒
这个问题解决了吗,我也遇到了同样问题
MichaelBranscomb
I believe your question is: "Has this problem been solved? I'm having the same issue."
This thread is an old issue that relates to support for Apple Silicon macs, which was added in April 2023. Please create a new post about the problem you are seeing, and include as much detail as possible (operating system, software versions, workflow).
Thanks
