Best way to include 3d objects/tile packages inside Unity build ?
2361
02-26-2024 11:29 PM
anzago
I'm trying to build an application that is using 3 local packages to load with the ArcGIS Unity SDK.
In the ArcGISMapComponent I can specify the "source" field for each layer but it seems to only support absolute path. Is there a way to reference a package that could be located inside the Unity "Resources" folder for instance ?
I think I can still configure the map from a C# script and use relative paths there, but I would prefer to have everything configured with the map component if it's possible.
Thankful for any help !
ws4945894
once I had a similar problem and got it resolved like that...
1) Create folder StreamingAssets (spelling matters!) on the same level as Scenes, Scripts and the like...
2) Use the following code snippet to access any files in folder StreamingAssets
string somePackageSlpkPath = Path.Combine(Application.streamingAssetsPath, "some_package.slpk");
ArcGIS3DObjectSceneLayer someLayer = new ArcGIS3DObjectSceneLayer(somePackageSlpkPath,
"SomeLayer", 1.0f, true, "");
The trick is to use Application.streamingAssetsPath which tells Unity to look into the StreamingAssets folder. This takes care of packaging any files in there into the build...
Hope this helps...
Best regards
Winfried
anzago
Your solution is working great for my layers !
Thanks a lot !
ws4945894
Glad to hear that, have fun!
JasonSosebee
Using the StreamingAssets folder solution works for displaying map layers offline, but the problem is the layers' visibility/opacity cannot be modified with script. For instance, the following code works when map layers are added using the Map Creator visual tool, but does not work when coding layers using the streaming assets path.
layerName.APIObject.IsVisible = !layerName.APIObject.IsVisible;
