Basemap and layers not showing
2072
9
12-14-2025 10:14 AM
RobertEkroll
When I configure a scene in Unity using the ArcGIS Maps SDK for Unity, none on the services I add show.
I have configured a token, and I am able to choose a basemap (they are colored in the Map Creator). But none of the basemaps I select show at all. The only thing that happens is when viewing the scene (that is empty) the CPU is going up to 20-30% and staying there.
My setup is Windows 11, the 2025 2H release.
I have tried to use Unity 2022.3.62 and in 6000.3 (6.3). Both is LTS versions.
In Unity 6.3 I tried both the 2.1 and 2.2 versions of ArcGIS Maps SDK for Unity.
I am not sure what to check, or what to try, next. Hope someone have some ideas or clues about what is happening.
and1
by Esri Contributor
Hi @RobertEkroll , since the basemap gallery are colored, that means at least we know API key is working correctly. How was your ArcGIS camera configured?
RobertEkroll
The ArcGIS camera was configured according to the tutorial Display a map (UI) | ArcGIS Maps SDK for Unity | Esri Developer
and1
by Esri Contributor
Thanks for showing the screenshot. The camera values looked correct. Could you also show another screenshot of the inspector window with ArcGISCamera game object being selected?
RobertEkroll
The ArcGISCamera in Inspector below. But I think that is OK - see text below image
Using Unity 2022.3.62 and SDK 2.2.0 - I also tried to create a new API token (I use the "new" developer portal - Location Platform). No luck, but I then tried to create an OAuth2 login, and when using the 2 hour temporary token, the selected basemap showed.
The API key have more privileges than the OAuth2. I have no layers except for basemap.
Do the API key need some special config?
and1
by Esri Contributor
Could you check if the basemap service is on when you created an API key? It should be enabled by default though.
https://developers.arcgis.com/documentation/security-and-authentication/api-key-authentication/tutor...
RobertEkroll
All services are enabled
and1
by Esri Contributor
If that's enabled, at least the basemap should be displayed. Could you go to Edit > Project Settings, in the ArcGIS Maps SDK tab, and enter your API key? Then check and see if you can load these sample scenes from Assets/Samples/ArcGIS Maps SDK for Unity/2.2/Sample Content/Scenes/ComponentGlobal.unity  ? If you are able to load the sample scenes, then we at least know your API key should be working.
RobertEkroll
I tried the API.unity.
In the Map creator the basemaps have color.
When clicking the different basemaps, I get the following error:
ArcGISViewState changed to : NoViewport, Error (Invalid API key.)
Additional info: The API key '*ESJMp' is invalid, expired, or does not have access to the resource 'https://basemapstyles-api.arcgis.com/arcgis/rest/services/styles/v2/webmaps/arcgis/charted-territory'.
So, how can I fix that access?
and1
by Esri Contributor
Thanks for sending that error message. I'll get back to you soon.
