About map initialization
862
07-25-2023 04:07 AM
jianghan8098
The following file is your sample code SampleAPIMapCreator, used to initialize the map, but the current problem is that the initialization speed is a little slow, almost need to run 3s or so, you can call the following two methods to convert latitude and longitude。
public static Vector3 GetUnityPosFromLatlon(ArcGISPoint latLon)
var cartesianPosition = arcGISMapComponent.View.GeographicToWorld(latLon);
return hPRoot.TransformPoint(cartesianPosition).ToVector3();
public static ArcGISPoint GetLatLonFromUnityPos(Vector3 vec)
var worldPosition = hPRoot.InverseTransformPoint(vec.ToDouble3());
return arcGISMapComponent.View.WorldToGeographic(worldPosition);
but the old version of Arcgis, the initialization speed is particularly fast。The older version of the initialization script was KDArcGISManager。look forward to your answer
